- 1/2 inch cp3 fuel fitting
- Silverado Window Regulators
- How to: Replace NSBU Switch.
- How To: Replace DMAX water pump in 1hr
- Installing PPE Crankcase Breather Set on 05 Duramax
- How To replace the door hinge pins on your Chevy truck
- How To upgrade the mirrors on your Chevy Silverado or GMC Sierra
- how to make glow plug switch manual operated *
- High Pressure fuel testing *
- Computers and Control Systems Locations
- Computers and Control Systems Locations *
- Duramax Diesel Fuel System - Fuel Injector Service *
- Head Gasket and Studs install *
- Had to replace a Glow Plug so here is some info.
- Diamond Eye 3" Turbo Down Pipe Duramax build thread!
- Replacing Duramax LB7 Injectors 01-04 tips and hints
- Dmax Replacing the FCA a.k.a. FPR
- How To Remove Your Allison
- Using EFI LIVE Tranny Controls Tip.
- Duramax Air Filter Testing *
- Insulating Boost And Intake Tubes DIY...
- Custom Bowtie
- Duramax Diesel Engine Removal
- Pure Flow Technologies Duramax Air Dog 100/150 Install Instructions
- BD-Power Duramax Exhaust Manifold Install Guide *
- PPE Boost Increase Valve Install Guide
- MBRP Turbo Back 4" exhaust Install Instructions Silverado/Sierra
- Fast Cheap Mod...Shaved Antenna
- DIY- PCV Reroute
- DIY- EGR Blocker Plate And Finger Stick
- Fuel Filter/Separator Drain Valve Repair
- Duramax Fuel Filter Replacement
- Transgo Jr Install Step By Step... Pics Included, Best I Could Do...
- Tie Rod Replacement *
- How To Level Tow Mirrors On A GMC
- Auto Headlight Disable
- coolant removal
- Do You Know Your Chevy???
- Allison & Converter Complete Flush Method
- NV4500 Breakdown
- Allison Code List, TQ Specs, And Other Info
- Wire Or Fuse..A Little Help Please.
- CP3 Modifications You Can Do Yourself!
- Duramax Engine Swap
- Some Useful Part Numbers
