02 F250 steering issues
Old Jun 11, 2012 | 07:29 AM
Clay 6.7L's Avatar
Default 02 F250 steering issues
My parents have an old former fleet 250 with 100k miles that they use on their farm. When you drive the truck over 30 MPH steering it really becomes a pain. It's almost stressful because keeping it straight requires constant little adjustments. Any ideas on what could remedy this?
Sent from my SAMSUNG-SGH-I847 using Tapatalk 2
Old Jun 11, 2012 | 10:17 AM
CSIPSD's Avatar
Could be any number of things, more then likely its a worn out steering box. But bad ball joints, Wheel bearings, drag links, track bar... all the front end issues can lead to that.
Old Jun 11, 2012 | 10:25 AM
Gaius's Avatar
You'll want to have someone dry steer it and look at all steering components. Check box and steering column play. You should be able to see if anything is loose. Also make sure the toe is set correctly.
Old Jun 11, 2012 | 10:26 AM
CSIPSD's Avatar
No "I" beams on a superduty F-250...
Old Jun 11, 2012 | 01:06 PM
artieb's Avatar
torque rod in steering box, I put a PSC pump and 285-75-16 tires and drives pretty good, play with air pressures in front, I am assuming it is a 4X4?
Old Jun 11, 2012 | 01:44 PM
Gaius's Avatar
Yeah, I realized I was in the SD forum right after I posted.
JPatt
Jul 29, 2015 03:25 PM
Boostaddiction
May 4, 2015 06:28 AM
BubbaDT55
Apr 12, 2015 10:47 PM
Polaris04
Dec 1, 2014 08:27 AM
sweetv8s10
Oct 7, 2014 09:47 PM
