95 7.3L oil cooler leak?
Old May 20, 2012 | 09:54 PM
suzan's Avatar
Default 95 7.3L oil cooler leak?
Need some help on how hard it will be to repair oil cooler on my 1995 7.3L Power Stroke, up untill lately never had a drop of anything under my truck first just a drop every once in awhile, and now we are talking a good size puddle Hoping someone can let me know how hard of a job this will be?
Old May 21, 2012 | 03:05 PM
CSIPSD's Avatar
Its not a bad job...
Drain the coolant, Drain the oil, Remove the oil filter...
Three bolts on the back and two bolts at the front.
Remove, seperate the three pieces and replace the O rings. Remove the gaskets from the block or housings and put it all back together...
Get the rebuild kit from Clay at RiffRaff Diesel...
Riffraff Diesel: Oil Cooler Seal Kit
Just did it on my truck a few weeks ago, took the two of us about 2 hours or so... Both of us are semi experanced...
Would block out an afternoon for a novice and a OBS (slightly less room then a superduty.
Old May 22, 2012 | 02:02 AM
suzan's Avatar
Default one question?
You say the coolant also needs to be drained
Old May 22, 2012 | 07:09 AM
Eddiebuntain's Avatar
Yup, both are run through the cooler so the coolant can remove the heat from the oil.
Old May 22, 2012 | 10:40 AM
CSIPSD's Avatar
Good install directions...
http://www.dieselorings.com/docs/OilCooler.pdf
Old May 24, 2012 | 12:08 AM
suzan's Avatar
Thank you all for the great information, guess I learn something new every day about my rig, I`ve had her since brand new, she`s been a real great truck, plan on keeping her forever I`ll let you know how the project goes, Thanks again
Old Aug 4, 2012 | 02:16 AM
suzan's Avatar
It took awhile, she`s all fixed now, took her out for a test drive today, just wanted to thank everyone for all the good advice, she would of been done alot sooner if the person who choose to do it for me hadn`t of gotton put on seven days a week 10 hour days at his real job, anyways she is leak free again, and running strong Thanks again this is the second time this site has helped me get my rig back on track, maybe someday I can return the favor
makuloco2000
Dec 20, 2015 11:19 PM
Crabber0001
6.0L Performance
Aug 4, 2015 12:30 PM
Bighouse
Apr 9, 2015 06:51 PM
ash23k
Dec 30, 2014 08:31 PM
bypass-21
Dec 15, 2014 08:52 AM
