Transmission crossmember question
Old Apr 19, 2012 | 07:21 PM
Rolson's Avatar
Default Transmission crossmember question
Hi everyone,
I'm slowly moving forward with my Ranger conversion, but I have run into a new issue I wasn't expecting.
The transmission crossmember from the truck has the rubber bushings in the end similar to the Mustang, but the steel pipe around the bushings at the passenger end is mostly rusted out and gone.
At first I thought I would just cut it out, weld in some new 1 1/4" pipe, get new bushings and re-use it. After looking around on several sites today I find that the bushings are not available to purchase. A couple of guys have replaced the whole crossmember with the style that bolts inside the frame rails from a Bronco II, or from an Explorer, depending on the year, and 4x2, or 4x4 tcase clearance issues.
Here is my scenario:
1990 Ranger, extended cab, 4x2
Mercedes OM617 turbo engine
1996 Jeep AX15 tranny
Should I a)continue to rebuild my crossmember and forget putting any bushings in it since the newer ones bolt directly to the frame? b) get one of the ones from the junkyard for $45 from an Explorer? or c) fabricate my own from a piece of 4" channel steel?
The Jeep tranny mount has a different bolt pattern than the Ranger anyway, 4 bolts vs. 2.
Any thoughts and comments are welcome!
Thanks everyone!
Old Apr 19, 2012 | 08:05 PM
Whit's Avatar
Site Mascot
I dont understand why it would need bushings, I think a solid bolt up would be fine
Old Apr 19, 2012 | 09:26 PM
Rolson's Avatar
Default Thanks, Whit
My old '99 Ranger had a solid bolted tranny crossmember so I don't know why it wouldn't work with this one. My only concern is if there may be a lot more vibration with the diesel engine vs. the old gasser 3.0.
Rick
Old Apr 20, 2012 | 12:37 AM
not enoughsmoke's Avatar
build your own i did out of 3in channel
Old Apr 20, 2012 | 07:05 AM
Rolson's Avatar
Default Nice work!
Looks sharp. Good work. I looked around my shop but I don't have a piece on hand that is long enough. Will walk through the salvage yard tomorrow and see if they have something I can use.
Rick
Max713
Apr 17, 2015 01:18 AM
02Stain
Feb 17, 2015 10:21 PM
SixSpeed
Jan 11, 2015 01:41 AM
Trevlar11
Dec 11, 2014 03:30 PM
TheDirtyDozen
Oct 1, 2014 10:09 AM
