1994 12v fummins wiring
Old Mar 19, 2012 | 12:14 AM
prowler48's Avatar
Default 1994 12v fummins wiring
hey can anyone give me a write up on how to wire up a 1994 12v cummins in my 1997 f250? any help is apreciated. thanks.
Old Mar 21, 2012 | 10:03 PM
megancheung's Avatar
i am wiring up my 4wd 95 chevy that used to be 6.5 diesel and auto and now has a 91 dodge 6bt swapped in and also i have converted to nv4500 5 speed as well.and have a questions:ran the chevy fuel heater wires to the dodge fuel heater?
And you?
Old Mar 22, 2012 | 07:43 PM
cumminsf150's Avatar
https://www.dieselbombers.com/diesel...onversion.html
that should help
Old Mar 25, 2012 | 12:37 AM
EasternAggie's Avatar
And you?
Don't worry about the fuel heater. It's basically worthless, and on top of that is prone to leaking and allowing air to get in the fuel system.
Theres not much to it at all. For the gauges, reuse the water temp and oil pressure senders out of the Ford engine and move them to the Dodge engine, and leave the senders hooked up in your wiring harness like they were. Between those two and a key on hot wire, they should be the only three wires you reuse out of your factory wiring harness. If you use the Dodge alternator, you'll have to wire up an external regulator so it will charge. The fuel shutoff solenoid is a simple three wire hookup. For the starter and starter solenoid, refer to the thread that CumminsF150 posted.
savage-rider
Sep 26, 2015 12:43 PM
jeremy01995
Sep 14, 2015 06:34 PM
cummins Pride
Apr 18, 2015 11:54 AM
atreefunk
For Sale
Apr 13, 2015 10:57 PM
Nov 16, 2014 05:14 AM
