E4od Trans troubles
Old Feb 13, 2012 | 09:23 AM
Seventhree's Avatar
Default E4od Trans troubles
Bought a Trans with 50k on it, money is tight these days. Put it in my truck. (95 f350 powerstroke) Trans came out of a 97 f350. Had maybe 40 miles on the Trans myself and now 4th gear slows the truck down till 35 mph. What went bad? The Trans or computer issue? When it first happened I did notice done smoke inside the cab.
Old Feb 13, 2012 | 09:31 AM
DieselDanBoy's Avatar
sounds like the clutch for 4th gear is hosed
smoke tells me that most likely that clutch wasnt engaging all the way and it slipped until it got hot enough to start smoking.
How does it shift through all the other gears? when you say it slows down the 35mph, does rpm go up or down or stay the same?
Old Feb 13, 2012 | 12:37 PM
Seventhree's Avatar
Shifts like a normal ford Trans, rpm in 4th is normal like it locks into 4th gear but something's binding inside and when I stab the throttle it'll downshift to 3rd and be normal till it try's to go into 4th. I've been keeping overdrive off
Old Feb 13, 2012 | 07:33 PM
so when it shifts into 4th, it'll start pulling engine rpm down and put it under a good load?
Old Feb 13, 2012 | 11:54 PM
Seventhree's Avatar
Correct.
Old Feb 14, 2012 | 09:29 AM
ok
I'm going to say this is just isolated to your overdrive/direct drive clutch or the planetary in that set. What I'm thinking is; something in the planetary is binding to the point where the clutch for over/direct drive can't hold anymore, it starts slipping and and smoking.
either way, the transmission needs to come out and apart to really see what's going on.
Old Feb 16, 2012 | 04:22 PM
Seventhree's Avatar
If I keep it overdrive off, it's fine just always wound out. Looks like the trucks heading to the tranny shop in the near future..
Old Feb 16, 2012 | 10:12 PM
yea just try not to keep it wound up too too long, i dont care what anyone says, it's not good for a 7.3.
but my opinion it's just one part giving you trouble, let us know how you make out!
Old Feb 16, 2012 | 11:41 PM
95powersmoker's Avatar
take it to someone who knows these transmissions... It's going to be more costly not doing it right the first time and doing it multiple times... Ask CSIPSD how much he has wrapped up in transmissions just in his 01...
Old Feb 17, 2012 | 07:58 AM
Seventhree's Avatar
The shop where it's going, did my old mans in his 02 psd, that has nice firm shifts. About 2k all said and done.
Jake9473
Jul 22, 2018 08:19 AM
PA 24valve
Aug 31, 2015 07:39 PM
Rabbitjbu
Jul 28, 2015 06:03 PM
mtedrick4
Diesel Engine Conversions
Oct 13, 2014 09:25 PM
Pyrohigh
Oct 11, 2014 07:59 AM
