cummins broke down
Old Dec 20, 2011 | 11:56 AM
mcneel102's Avatar
Default cummins broke down
i have a 2000 dodge 2500 that i was driving and it shut down like it was outta diesel i pulled the fuel line off my air dog bumped the key diesel poured out like it should i took off #1 injector line bumped it again diesel was coming out and put it back on but still didnt start then sprayed starting fluid in the air intake and it tried to start but it didnt so i have no clue what it could be so if anyone could help me out please do
thanks connor
Old Dec 20, 2011 | 12:07 PM
MillerBoyzDiesel's Avatar
you got fog lights on that truck?
Old Dec 20, 2011 | 12:39 PM
NadirPoint's Avatar
VP44 died?
Old Dec 20, 2011 | 12:42 PM
mcneel102's Avatar
No I don't have fog lights? And also I have no clue how to know if the vp died
Old Dec 20, 2011 | 12:48 PM
well see if you can find another relay to swap out with the fuel sys. relay in your underhod fuse box. then crack your injector lines and see what happens. Usually I use the fog lamp relay for the swap, should be another one under there you can use
Old Dec 21, 2011 | 08:50 AM
NadirPoint's Avatar
That's just what it sounds like to me. Pulling codes will tell the story.
Old Dec 21, 2011 | 08:04 PM
biged681985's Avatar
pull codes - 3 key cycles
p0216 code - need new vp44
no codes - check fuel pressure from lift pump
no pressure - check relay
good relay - change lift pump
low pressure - change filter bleed all 6 lines
new filter low pressure - change lift pump bleed all 6 lines
if you only get fuel out of 3 lines - new vp44 likly
if it still dosnt start then your probably going to need a new vp44
Old Dec 21, 2011 | 10:48 PM
1993firstgennewbie's Avatar
get a 12 valve
Shun70
Diesel Engine Conversions
Sep 21, 2015 01:39 AM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
Oct 20, 2014 08:10 AM
