Audio Equipment/Electrical Discussions Based on Automotive Stereo Equipment Such As Amps , Head Units & Speakers Including Installation and System Set Up Information. Electrical or wiring issues on anything that requires wiring.
06 audio question
Old Jul 29, 2011 | 05:11 PM
rednekroper05's Avatar
Default 06 audio question
Ok first off what would cause my stock head unit to work intermittently? It may work and then I cut my key off and it may not work again or it may its really starting to get on my nerves.
Second if I do replace my head unit can I use the stock navigation unit plastic from a truck and use a double din unit?
Old Jul 31, 2011 | 04:07 AM
Deezel Stink3r's Avatar
I can only answer the first question.
90% of all interruptions are caused by bad wiring. Check the connectors to and from the head unit to power supply and in this special case the ACC power line. Keep a special eye on ground returns. For some reasons they are mostly overlooked.
Old Jul 31, 2011 | 09:57 PM
CHEMMINS's Avatar
Yes, actually I just exchanged my stock deck that was non-nav, for a trim panel that is nav, and installed a double din alpine deck. Easy as pie.
Old Aug 6, 2011 | 09:08 PM
dalton06's Avatar
I need help with mine also. The screen quit working 99% of the time. Every now and then it will come back on for a min or so then go back off. Station buttons still work but u can't switch to cd. Any clues?
This was when it just randomly came on few weeks ago but went back off.
Old Aug 7, 2011 | 08:30 PM
CHEMMINS's Avatar
Try totally disconnecting the harness from the deck, then plugging it back in. Cause a reset. This can sometime help frozen decks. Next option is to buy a nice aftermarket double din.
Old Aug 9, 2011 | 04:47 AM
Usually when the display fails, dirt in the plastic conductor is the cause.
Yah, you are reading right: "plastic conductor". It is a small strip connecting the display with the on-board PCB.
Tech alcohol and cotton swabs can be used to clean the connector. Do not try this by yourself. It's a job for the trained technican.
Joracing3
Sep 10, 2016 05:28 PM
torg73
May 11, 2015 03:08 AM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
carid
Diesel Bombers Sponsors
Dec 4, 2014 05:25 AM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
