24v hard start hot but not cold
Old Jun 2, 2011 | 05:15 PM
keithduke01's Avatar
Default 24v hard start hot but not cold
truck has no problem starting cold, but is hard to start once it is warmed up, the injection pump and lift pump were replaced only 2 weeks ago, been doing this ever since. anyone have any ideas, im lost!
Old Jun 4, 2011 | 03:06 AM
cummin_un_glued's Avatar
FormerVendor
which lift pump did u put on it?
Old Jun 5, 2011 | 11:45 AM
they replaced the stock style lift pump with the in tank style but its still mounted on the side of the block, they went from the carter type to the cylindrical in tank style and i think the fuel is bleeding back through the pump anyone else ever have this problem?
Old Jun 5, 2011 | 12:05 PM
RAW's Avatar
RAW
Is the new pump in the tank, or on the block?
Old Jun 5, 2011 | 03:44 PM
FormerVendor
that sounds like possibly a airtex pump like from oreillys or other parts stores are selling, we have been seeing LOTS of problems with those pumps causing hard starts, i would change the lift pump back to a stock style carter and see if the problem go's away or switch to an aftermarket pump
Old Jun 5, 2011 | 07:31 PM
its looks a lot like an airtex pump like for a chevrolet, but its mounted on the block where the old carter style pump was mounted. the truck has pressure cold because the pump runs a lil when you turn the key on with the engine cold, but when the engine is warm the pump does not run when the key is turned on, and if you crank the engine and make the pump run like your bleeding out air then immediately go back to crank it it fires, but it takes only 30 sec after key off for the pressure to bleed to 0 psi.
94turbostroker
Feb 26, 2016 07:51 PM
dandbmcc
Mar 14, 2015 11:05 PM
trab123
Feb 9, 2015 09:44 AM
Downd19
Dec 30, 2014 02:49 PM
custom7.3
Nov 23, 2014 10:44 PM
