starting 7.3
Hi,is there a way to start a 7.3 without the steering column,dash is still in truck.
What wires could you energize to get pcm to light up without burning pcm,need to start engine to prove that it is good,thanks
Thats what i did,but all got was the engine to turn over and if i remember right thats how
we used to do it with gas engines,but i think we had complete the connection from the
relay and i thought we had to move the small to the other terminal just did want burn up
the PCM,but does the PCM get 12volts,thanks
ok. this would be attached to the bottom of the steering column. it might not be there. it's a white box with a metal peg sticking out. this is your ignition switch. if you push on it, it should have multiple spots where it stops, just like turning the key on. go as far as it will go, the last position will spring back. just like using a key.
the steering column was removed the truck has turned into a money pit,
too many miles and trany bit the dust,scraping truck.
There was a black block with bolt in it is this what was talked about,we were under
the impression that there was rod going from ignition key to box,will go out and look at box
with bolt again,thanks
Went out and looked at black connector there is a bolt in it but it is a female connection
I would be willing to bet there was a electrical connection from steering column to this black connector,thanks
Browe347
Dec 11, 2016 02:59 PM
Excursion73
Oct 27, 2015 05:21 PM
Locoster
Jun 22, 2015 10:54 AM
