lly head swap
Old Apr 26, 2011 | 08:59 AM
cfarley0210's Avatar
Default lly head swap
So i heard you can take the lly heads and stick them on the lb7 and then you can run the vgt turbo. I was just curious if anyone had done this? And what it would take to do it. Wouldnt you have t swap over the ecu and wiring harness also?
Old Apr 26, 2011 | 09:02 PM
BriteWhiteRam's Avatar
More than likely you would have to swap the ECM over.... the only advantage i see from that is the injectors.... it would be really tough to do tho, the ECM probably wouldnt be happy with many things....
Old Apr 27, 2011 | 02:03 AM
2500HeavyDuty's Avatar
there has been one guy who just straight swapped them over, but he had a 03-04 model
there is a huge electrical difference between the two. the lb7 uses 96v to actuate the injectors and lly use 48v iirc.
the wire harness is different and the computer as well.
and if you have a 01-02 dmax forget it, you have so much more electronics to deal with then just a straight ecm/ficm swap.
PCTechman
Sep 13, 2015 12:15 PM
TheMacster
5.9L 24V Performance
Apr 14, 2015 07:01 PM
spark'd
Feb 7, 2015 02:07 PM
SMCCARY
Diesel Engine Conversions
Jan 23, 2015 02:16 PM
Adam65
Jan 9, 2015 11:50 PM
