Timing issue
Old Apr 21, 2011 | 09:51 PM
7.3 Cowboy's Avatar
Default Timing issue
On my dads 96 2500 auto that is all stock besides exhaust and intake if you rev it while on park it starts to cut out at about 1800 to 2100 rpm and throws white smoke but before and adtwe those speeds it it just fine and runs good. Is my thinking right about it being the timing?
Sent from my DROIDX using Tapatalk
Old Apr 22, 2011 | 08:23 PM
heavy hauler's Avatar
Could be but what does the truck do when under a load at those RPM. Whe you build boost it probably will run fine. If you want to reset the timing you can always pin the pump and motor and get it to stock timing.
Old Apr 23, 2011 | 10:04 AM
7.3 Cowboy's Avatar
it runs just fine under a load during those rpms
Old Apr 23, 2011 | 04:51 PM
I would reset the timing and start from there and see what it does. Probably needs to be advanced a little.
Old Apr 24, 2011 | 08:38 AM
7.3 Cowboy's Avatar
Default Re: Timing issue
Like would 16 degrees be to much for that stock of a truck
Old Apr 24, 2011 | 02:42 PM
captain_stabbin's Avatar
16 would be fine
Old Apr 24, 2011 | 03:12 PM
7.3 Cowboy's Avatar
Thanks Ill try that after I get my timing set in
Dec 10, 2019 10:10 AM
quiksilver1j
Jul 30, 2015 12:41 PM
Stox5225
22
May 14, 2015 05:17 PM
SMatyac
Nov 15, 2014 07:35 PM
jjbced
Oct 26, 2014 09:09 PM
