killer pin
Old Apr 9, 2011 | 12:10 PM
tomcowboy's Avatar
Default killer pin
picked up a used motor and I was inspecting it. When I pulled the front cover the killer pin was missing. Do I need to replace it or? the motor was running well when I pulled it.
Thanks!
Old Apr 9, 2011 | 12:12 PM
RAW's Avatar
RAW
I strongly suggest replacing it and putting a KDP retainer on it. Keeping that housing in its proper location is a damn good idea. At this point, the bolts should, SHOULD being the key word, hold everything in place. The holes in the housing will have some wiggle room though, and it may walk around on you.
Old Apr 9, 2011 | 02:27 PM
tomcowboy's Avatar
Ok, thanks, but if I understand you it's only purpose is to keep the housing aligned. Thanks again, I'll see if I can get one at Dodge.
Old Apr 9, 2011 | 05:20 PM
daveO's Avatar
Here ya go
Cummins Dowel Pin 5.9L 12 Valve Diesel Gear Case 3900257
Aug 25, 2015 07:10 PM
windage
Jul 17, 2015 12:45 PM
Weeks327
May 11, 2015 10:43 AM
359ci12v
Apr 9, 2015 08:24 AM
dieseldeal
Mar 24, 2015 12:11 AM
