Lift Pumps
Old Dec 11, 2007 | 02:43 PM
DieselfreakMI's Avatar
Default Lift Pumps
Are the lift pumps for the 1st gen. and 2nd gen 12v interchangeable?
I am considering running my truck on Veg Oil, and from what I read suggests to install a more robust lift pump and the 2nd gens pistion type is stronger than a 1st gens diaphragm type. I figure if I can swap it out it would more cost effective. Otherwise its saving for Fass pump or something.
Old Dec 12, 2007 | 08:07 AM
LOGANSTANFORTH's Avatar
yes, alot of first gen. guys do the swap....
Old Dec 12, 2007 | 11:50 AM
Begle1's Avatar
They're not directly interchangeable. There are two kinds of piston lift pumps; 1st gen and 2nd gen. The 2nd gen one puts out a ton more pressure due to internal differences, and has a bigger piston in it. I hear that it is possible to rebuild the 2nd gen pump with a 1st gen rebuild kit in order to keep the big piston and cut things down to the lower pressure. Or you can run a pressure-regulated bypass on the 2nd gen pump to keep fuel pressure down.
Both pumps require a mounting spacer and a new fuel line to install. And you need to either find a low-profile compression nut for the top or hack away some block insulation with an exacto knife.
Old Dec 12, 2007 | 04:37 PM
what years of first gens. had a piston type lift pump on them?
Yeah I definatly have a diaphragm type.
Last edited by DieselfreakMI; Dec 12, 2007 at 04:37 PM. Reason: Automerged Doublepost
Old Dec 12, 2007 | 08:03 PM
Begle1's Avatar
All of the first gens had the diaphragms, so I guess that "1st gen piston pump" is kind of a misnomer. It's really a "VE pump piston pump" that I assume was used on the VE-equipped motors in different applications.
Old Dec 13, 2007 | 12:01 AM
ok sorry about that, thanks Begle, i forgot they werent interchangeable....
Old Dec 13, 2007 | 01:42 PM
welderboy250's Avatar
how bout some sort of an electric lift pump before the mechanical lift pump? ive been using biodiesel and it thickens up a lot in the cold and ive been lookin into and electric flow through pump that i only have to run when i want to. any info on such a pump would be apriciated
Old Jan 17, 2008 | 12:45 PM
Does anyone know where I can pick up a pistion type lift pump for my 1st gen.?
Old Jan 22, 2008 | 08:37 AM
Skeye's Avatar
Actually, there's at least three different bolt-on piston pump replacements for the Cummins 5.9, with different pressure/flow rates. Original Part#s (superceded):
3936320 - 15psi (listed as CASE tractor and 4B parts)
3936323 - >18? (listed for 4B)
and various numbers for the 2nd gen pumps, higer pressures (?)
The the 3936320 is the only one that should be considered compatible with the VE on your engine, from a pressure standpoint.
Old Jan 22, 2008 | 04:56 PM
alright thanks
landon025
Sep 8, 2015 09:21 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
Callmecowboy
18
Feb 3, 2015 09:01 PM
Callmecowboy
Jan 22, 2015 04:39 PM
