Oil Tube to oilpan on om617
Old Mar 23, 2011 | 07:32 AM
Corvette74's Avatar
Default Oil Tube to oilpan on om617
what is the best way to handle this oil tube
I have hook the breather from the valve cover to my intake pipe but not sure what
would be the best way to handle this tube
Old Mar 23, 2011 | 07:56 AM
Walkenvol's Avatar
Are you referring to the metal tube that runs from the turbo around the back of the motor? If so, I understood that to be the required oil supply to the turbo.
Old Mar 23, 2011 | 09:13 AM
Corvette74's Avatar
No this line ran from the airfilter to the oil pan in the MB
Old Mar 24, 2011 | 12:24 PM
FTE's Avatar
FTE
It is the oil return drain from the valve cover breather. It is there to recapture oil from excessive blow-by, the pressure was vented to the air cleaner, then the oil drains back to the pan.
Old Mar 24, 2011 | 12:55 PM
Corvette74's Avatar
If I run a line from the valve cover breather to my air intake on my turbo would there be to much oil going into the turbo and them just cap that return line.
Vette
Old Mar 24, 2011 | 11:02 PM
FTE's Avatar
FTE
As long as you don't have too much blow-by. My 85 cali motor didn't have the drain tube, it used a different air cleaner and basically ran the breather tube to the top of the air cleaner.
Old Mar 25, 2011 | 05:14 AM
Corvette74's Avatar
Would the worst time it would do is just burn the oil from the blow by?
Vette.
Old Mar 25, 2011 | 01:14 PM
deck60's Avatar
take a piece of 1.250 black pipe nipple 4" long put a cap on 1 end drill a bunch of .250 holes in stuff it full of steel wool and on the bottom make a fitting that will fit into the return and on the side weld in a fitting that will adapt to the blow by tube should work
then it will drain back into pan
Durtyd09
Nov 11, 2015 01:43 PM
|WYG|SS
Aug 19, 2015 10:53 AM
soco
Jul 27, 2015 06:06 PM
jhprice
Mar 29, 2015 09:36 PM
12Valvepower01
30
Nov 11, 2014 10:52 AM
