Gear Ratios
Old Feb 4, 2011 | 08:19 PM
SquirrelCrusher's Avatar
Default Gear Ratios
Any way to figure out what gear ratio is in a 95 suburban without pulling the cover or jacking a wheel up? It is a 95 3/4 ton 4x4 with a 6.5t What rear ends and ratios came in these things?
Old Feb 4, 2011 | 08:48 PM
collinscummins's Avatar
From what i read its on the door panel, or you can check the inspection plate on the rear diff. but im sure this will only give a general idea, probably need to reference it with some part number or something. Could just paint a white spot on the drive line and another on the tire and have someone roll it while you count the rotations or vice versa
Old Feb 4, 2011 | 09:32 PM
Woody35's Avatar
look in the glovebox for the rpo codes. its going to be a code starting with a g. with yours being a 3/4 ton its either going to be either 3.73 or 4.10 rear gears. google chevy rpo codes with the code you found
Old Feb 4, 2011 | 09:38 PM
Crazy's Avatar
X2 on what Woody35 said
Momo12valve
12
Oct 18, 2015 04:19 AM
Jun 4, 2015 09:30 PM
bigdaddy0608
Feb 26, 2015 04:52 AM
rtbcoop
Nov 29, 2014 11:33 PM
Spiderman
Oct 6, 2014 09:52 AM
