powerstroke help
Old Jan 24, 2011 | 01:43 PM
casey_troutt's Avatar
Default powerstroke help
hey guys! i need some help. my 97 powerstroke quit on me. before it would stall out while driving and restart immediately. i was blowing a 30 amp fuse for the glow plug relay. my relay was bad but after i replaced it still wont start. removed fuel filter and drained. the filter fills with fuel when cranking so i dont believe its a pump. i replaced the cps and still no luck. i have also ohmed out my glow plugs and they all test good. any ideas?
Old Jan 24, 2011 | 02:55 PM
CSIPSD's Avatar
Your Fuel bowl heater is shorting out. Unplug the fuel bowl heater and replace the fuse.
Old Jan 24, 2011 | 03:56 PM
the fuse is good. my problem is getting it to start now
Old Jan 24, 2011 | 04:02 PM
CSIPSD's Avatar
Have you unplugged the fuel bowl?
If the fuel bowl heater is shorted, the minute you turn the key it will short again, killing the power to the PCM. If your not getting your scan tool to hook up, you do not have power to the PCM, and the truck will not start.
Old Jan 24, 2011 | 06:06 PM
97dieselnewb's Avatar
If you replace the fuel bowl heater, replace it with the international one, way better design, cheaper too
makuloco2000
Dec 20, 2015 11:19 PM
Lsugod85
Jun 20, 2015 05:14 PM
makuloco2000
Feb 15, 2015 02:31 PM
leaderbeanjr
For Sale
Jan 20, 2015 01:22 PM
southernbelle14
6.0L Performance
Dec 29, 2014 10:53 AM
