New lift pump in 12v leaking
Old Nov 14, 2010 | 03:49 PM
MauiBuilt's Avatar
Default New lift pump in 12v leaking
Changed out the old lift pump.. know i put gasket in.. primed the **** out of it. Now its leaking all over.. Any body changed there lift pump and had this happen.. Mmmmm diesel all over computer.. bet it will be clean now. should i undo all the connections and do em again.. I think its comin from the metal line on top.. ummm is thread tape on the fitting ok? HELP
Old Nov 15, 2010 | 03:56 PM
MauiBuilt's Avatar
Well I thread taped it and it still drips, umm going to try and tighten it a bit more.
Guess i should donate to this site then i'll get some help.
Old Nov 15, 2010 | 06:17 PM
cummin_un_glued's Avatar
FormerVendor
i've had those metal lines leak before only way i stopped it was a new line...mine leaked at the top where the compression fitting part is
Old Nov 15, 2010 | 11:15 PM
MauiBuilt's Avatar
Yeah that's what I was afraid of. Think fuel proof gasket maker
Might work? Gonna try I think. I don't think I can get that part
On island. Thanks
Old Nov 16, 2010 | 06:15 PM
FormerVendor
i doubt it pressure is 35psi
Old Nov 16, 2010 | 06:23 PM
Alligator Vinny's Avatar
Site Sponsor - Alligator Performance
There is a rubber O ring in there that you may need to replace. I replaced all the O rings when I changed out my lift pump. It's a basterd working down in that hole. Helps if you remove the inner fender liner and turn the steering wheel all the way to the right and you can work on it a lot better.
Old Nov 18, 2010 | 12:10 PM
MauiBuilt's Avatar
There's an o ring in there? That could be the prob. I never put one in, did not notice one in there. Would you happen to know the size. I bet thats it. Thanks alot. I hope that the fix i was looking for. Thank you, thank you, thank you.
Old Nov 18, 2010 | 01:58 PM
Never use thread tape - both Loctite, Swagelok, and 3M make a teflon paste. Or you can also use Permatex #2 for thread sealant.
I believe you are looking for 14mm sealing washers - they are cheap buy a bunch and have them on hand for whenever your working on your fuel system.
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
