white smoke ?????
Old Nov 8, 2010 | 09:51 PM
99powerstroke's Avatar
Default white smoke ?????
when i start the truck up a get a lil poof of grayish smoke then when i get it up to temp and giv-r and let off i get a big cloud of white smoke and after that some times it does it at idle ill get some white smoke pushing out but not alot any ideas whats going on here the only thing i have done to the truck is 3.5 down pipe to a 4 inch straight pipe any kinda help would be great thanks
Old Nov 9, 2010 | 08:07 AM
Jagsdiesel's Avatar
Diesel Bombers Sponsor- Jags Diesel
First off welcome to Diesel Bombers.
Second sounds like one of two things. Either you have a fuel injector/s leaking down and over fueling a cylinder/s. Or you have an oil burner. Could be excess blow by and causing it to get to much oil in the charge are system.
Old Nov 9, 2010 | 12:28 PM
well its only started since i did my straight pipe if that helps and if it was over fuel wouldn't that mean black smoke and i check the oil all the time and its not reading that im loosing any oil
Old Nov 14, 2010 | 05:06 PM
95powersmoker's Avatar
oil is usually blue, fuel can either be black or white. How old are your glow plugs? If your glow plugs are bad, you will usually have white smoke on start up. Does your coolant level ever change?
Old Nov 14, 2010 | 07:12 PM
my glow plugs are newer and coolant level stays the same for the most part this is my first diesel so still learning the ins and outs but thanks im going to take it to the local shop and see if they can tell me whats up
mattshow123
14
Mar 12, 2018 01:41 PM
coolf250
Dec 2, 2017 12:30 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
sgreen3
Feb 24, 2015 03:34 PM
zoomer10h
Feb 6, 2015 01:38 AM
