Transmission radiator LEAK!!
Old Oct 17, 2010 | 07:48 PM
DuramaxDiesel02's Avatar
Default Transmission radiator LEAK!!
So I was underneath my truck today and I found what looks like oil all over the tranny underside,inside front wheel wells,a-arms and all of that stuff upfront,and even under(uptop) of the small plastic skid plate under front bumper.
I took off the front grill to see if it was something up there and my whole bottom part of the main radiator and behind the bumper area was covered in black oily goe. And I tracked it to behind the small radiator that sits infront and at the bottom of the main radiator. And got my finger all around it to collect what it was and I found out it was tranny fluid.
I'm hoping this would be easy to fix? Where's the best place to take it? Local car dealer? Order part and install myself??
If u need pics I can take some tommorow when its light out.
Thanks so much.
Old Oct 17, 2010 | 08:35 PM
chevyhoss's Avatar
go on to autozone.com and create an acount itll tell u how to do it but the cooler may be surprisingly expensive
Old Oct 18, 2010 | 04:44 PM
Default Re: Transmission radiator LEAK!!
Thanks! Got the part same day about $270
Sent from my Droid using Tapatalk
Max713
Apr 17, 2015 01:18 AM
02Stain
Feb 17, 2015 10:21 PM
SixSpeed
Jan 11, 2015 01:41 AM
W350-4x4
Nov 12, 2014 09:35 AM
TheDirtyDozen
Oct 1, 2014 10:09 AM
