95 12valve braking problem
Old Aug 27, 2010 | 06:09 PM
Mike H's Avatar
Default 95 12valve braking problem
this morning when i started up my truck i noticed that the brake pedal was very soft and only responsive ,at the almost floor position.It works good enough that i made it to school and back no prob ,but im just a little nervous bout what it is seeing how i just bought the truck.I know there are dodge cummins experts on here so please help out fellow dodge guy asap!thanks,mike.
Old Aug 27, 2010 | 08:33 PM
tiremann9669's Avatar
Try some brake fluid, and look for leaks
Old Aug 27, 2010 | 10:08 PM
Mike H's Avatar
yeah brake fluid was the first thing i did.it was firm but i will push and hold and it slowly moves.i admit i havent taken it on the road but , any other ideas?
Old Aug 27, 2010 | 10:13 PM
Well if you're sure there's no leaks, they might need to be bled, or you could have a bad master cylinder. Also rear brakes out of adjustment could cause a low pedal but wouldn't cause it to drift down
Old Aug 28, 2010 | 01:10 PM
Mike H's Avatar
ok i feel like a dumb a**.i just found that there is brake fluid on the caliper.i cant tell if it is coming from the line or calipercuz its to dark out.any thoughts which one is most likely to leak?
alright just replaced the line,works fine now.thanks tireman!
burndiesel
10
Feb 7, 2023 01:15 AM
Jake9473
Jul 22, 2018 08:19 AM
jeremy01995
Sep 14, 2015 06:34 PM
rajdiesel
Mar 14, 2015 07:11 AM
signoremint
13
Oct 21, 2014 07:21 PM
