transmission imidiate attntion
Old May 26, 2010 | 06:01 PM
smoking62's Avatar
Default transmission imidiate attntion
i have a 6.2 with a 700 r4 and it slipps until 3rd but when i top it off with fluid its fine for a while when it gets hot it leaks and one guy told me my tranny was boiling fluid any idias a flush maybe what do i have to do to flush it? what parts needed
Old May 26, 2010 | 07:45 PM
2MuchJunk's Avatar
You can clean it out with about anything mineral spirits or any solvent and compressed air. It should be in the radiator so it shouldn't be to complex of a cooler. If you don't rebuild the trans it will probably do the same thing.
Old May 27, 2010 | 12:52 AM
smoking62's Avatar
well i dont think its clogged any more it just leaks from it looks like above the starter and i think it just leaks and then slips cause fluid shortage any clue what it could be leaking from
Old May 27, 2010 | 05:58 PM
2MuchJunk's Avatar
Is it leaking on the out side of the bell or on the in side? If it is leaking on the out side the only two things I can think of is if the oil cooler lines run above the starter but I don't think they do. It is probably leaking out of the dipstick. The question is if it is coming out of the top of the dipstick or if there is a hole in the tube.
Old May 27, 2010 | 10:18 PM
smoking62's Avatar
i guess it could have a hole do you know where the speedo or tv line runs
Old May 27, 2010 | 11:02 PM
2MuchJunk's Avatar
The speedo runs into the tell housing and I am not sure what you are calling a tv line. I don't know it's late and my brain is not firing all of them.
Old May 28, 2010 | 02:19 AM
smoking62's Avatar
ya it is late the tv cable goes to the injector pump from the tranny
Old Jun 16, 2010 | 03:33 AM
smoking62's Avatar
any body have any ideas
Max713
Apr 17, 2015 01:18 AM
02Stain
Feb 17, 2015 10:21 PM
SixSpeed
Jan 11, 2015 01:41 AM
W350-4x4
Nov 12, 2014 09:35 AM
TheDirtyDozen
Oct 1, 2014 10:09 AM
