lift pump not running
Old May 18, 2010 | 11:11 PM
mobetter's Avatar
Default lift pump not running
I have a 2001 that has just been rebuilt and the lift pump is not running. It works on the bench but not in the vehicle. fuses good relay good not getting voltage at the connector. Have double checked everything. Thinking possible ground problem because no continuity to ground. is there a separate ground wire that I have possibly overlooked??
I forgot to mention its a 2001 dodge 3500
Old May 19, 2010 | 08:16 AM
Whit's Avatar
Site Mascot
I dont think there is a seperate ground, clean all connections with lectramotive type spray then use sone conductive goo when you go back to gether with it.
are you sure the relay is delivering powa
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
