2007 Classic Duramax starting issues
Old May 1, 2010 | 09:36 PM
ljpumphrey's Avatar
Default 2007 Classic Duramax starting issues
The truck runs fine except now it takes longer to start. It is turning over around 8 - 10 times. I used to start right up. Sometimes it takes longer to start. Fuel filter has 80% life. I have noticed fuel dripping out of bottom of filter (out of the pitcock I think that is what it is called. Please help
Old May 1, 2010 | 09:44 PM
wildbill's Avatar
Check and make sure the petcock isn't loose, or rather the entire filter. Might have to remove the filter, clean the gasket and the face of the housing, then reinstall the filter.
Old May 2, 2010 | 11:38 AM
Diesel Nut's Avatar
Sounds like loos of prime. If fuel can get out, air can get in, and you don't have a lift pump of any sort stock. Your system relies on holding prime. I bet if you crack the bleeder screw and pump on the primer pump it will fire right up.
Fix your leak, I would either tighten or replace both the fuel filter and petcock if need be, then prime it and see if the problem persists.
Old May 2, 2010 | 07:57 PM
ljpumphrey's Avatar
I changed fuel filter today with no luck. I believe it may be the wif sensor. I will change and hope for the best. If this does not work then off to the shop. Does anyone know of a good diesel mechanic in the Manassas, VA area
Old May 4, 2010 | 06:10 PM
ljpumphrey's Avatar
WIF Sensor did the trick.
Old May 4, 2010 | 06:50 PM
Diesel Nut's Avatar
Good to hear.
Old May 4, 2010 | 07:13 PM
wildbill's Avatar
K, will close the thread down.
rowekmr
For Sale
Jun 12, 2015 11:03 PM
ronstop
Feb 26, 2015 09:48 AM
rschriek
Feb 3, 2015 10:13 AM
Dec 3, 2014 08:10 AM
BoostedSix
Nov 7, 2014 04:54 PM
