Suburban 1996 Actuator problem ???
Old Mar 18, 2010 | 06:06 PM
Falk65's Avatar
Default Suburban 1996 Actuator problem ???
Hi Guy´s i have put in a new front axle actuator and now the fuse for 4x4 in the driver side dashboard fusebox is always blown after he try to engage the front axle but i hear nothing just the hissing sound when the fuse blow and those light for the 4x4 ***** blinks
I hear the transfer case actuator works but nothing happening in the front
So what can it be
New Actuator new fuse still blowing
might be a bad wiring on the way from dash to Connector of the Actuator
I have no Pictures but i look at the old connector and it has a two letters on the Plastic where those 2 pin comes out of it A and B and same on the new one A and B and i cut the old Plug from the old actuator and do the same with the new one and Weights together with Thermal Connector the Old A to a new A and same with the B wire
and after i finished i put a heat shrinking tube over all connections
from this company http://www.autec-electronics.com/pro.../deray-vt-220/
But i am stuck but need my 4x4 to work
ok nobody have a clue then i have to find out the tuff way
Old Mar 18, 2010 | 07:33 PM
Woody35's Avatar
trial and error. never worked on these things. one thing that has always worked on my truck.
Old Mar 27, 2010 | 02:56 PM
Falk65's Avatar
Ok now i have remove the actuator from the Axle again and push the button when he is out of the axle and he works fine
put it back in and push the button the fuse blow at same time he push the axle in work and lights starts to blink again after one sec of a steady 4x4 light on button
I can hear the engine sound change after about 4 to 8 sec and then he blow the fuse
what can it be something stiff or stuck in the front axle interior
Old Mar 27, 2010 | 03:44 PM
2MuchJunk's Avatar
There are two splined shafts that face each other with a collar that slides over them ran by the actuator. The shafts are two piece and are pressed together. Most likely one of them has cam of the axle shaft. Take the actuator out and put a screwdriver in the hole and see if you can push the plunger inside the axle down. If not I would say it has come apart.You will have to pull the end of the axle housing to make sure but that is what mine did. I just got another Axle shaft and housing from the junk yard and put it in it.
I thought I replied to this post when it first started. I guess not sorry.
ILLUSHA
Diesel Engine Conversions
10
Aug 21, 2015 05:48 AM
Stone007
Tech Article Submission
Jul 3, 2015 01:28 PM
Radioking1777
Jun 8, 2015 10:26 PM
rajdiesel
Mar 14, 2015 07:11 AM
jrsavoie
Feb 6, 2015 12:32 PM
