Injection Question
Old Jan 21, 2010 | 10:46 PM
spud's Avatar
Default Injection Question
I have had a 1994 Dodge 2500 4X4 5 speed for about two years now
been good dependable work truck. But always under powered
I installed a pyro gauge and boost gauge so i could montior whats what.
even under a load never got above 5-7psi or above 800 degrees.
So i did an air intake kit, removing the stock air box and running a donaldson airfilter
truck seems to breathe much better and helped with the boost a little still under powered
Last thing i did is remove the convertor and muffler and run strait 3 inch pipe all the way out the back
This seemed to make the boost better but still under powered compared to others i have driven
Also throughout this whole experiment, I dont get any smoke whatsoever.
I believe the next step is the pump adj.
Any advice would be much appreciated.
Thanks
Spud
Old Jan 22, 2010 | 01:45 AM
97cummins's Avatar
This is the introduce yourself section.If you post your question in the dodge cummins section,you'll get a better responce.You could try movin you fuel plate ahead some.
Old Jan 22, 2010 | 03:47 AM
turbo20psi's Avatar
Welcome to DB.
Old Jan 24, 2010 | 01:41 AM
01trailerpuller's Avatar
Old Jan 24, 2010 | 06:11 AM
mishkaya's Avatar
You can find answers to many of your questions here:
https://www.dieselbombers.com/5-9l-1...-12-valve.html
Good luck!
Old Jan 24, 2010 | 06:25 AM
Jazz's Avatar
Welcome to Diesel Bombers
Old Jan 24, 2010 | 09:10 AM
ArizonaRedneck's Avatar
welcome to diesel bombers the #1 diesel dite out there
Old Jan 24, 2010 | 09:16 AM
sidekick's Avatar
welcome there is a lot of info out here
Old Jan 25, 2010 | 06:43 AM
DIESELDENT's Avatar
Welcome to db
Joracing3
Sep 10, 2016 05:28 PM
torg73
May 11, 2015 03:08 AM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
rtbcoop
Nov 29, 2014 11:33 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
