star wheel adjustment
Old Jan 12, 2010 | 07:57 PM
12v1911's Avatar
Default star wheel adjustment
hey everyone first time cummins owner here, my truck is stock and is a little sluggish. ive read alot on fuel plates and what they can do to a stock tranny, but im not ready to dump a bunch of money into tranny upgrades at this time. i was wondering if there is much advantage to adjusting the star wheel. also will it do any harm to the tranny or egt's????
Old Jan 12, 2010 | 08:00 PM
12vcummins96's Avatar
all this will do is start fueling the truck at less boost remove the afc and push the plate full foward and then adjust the afc
Old Jan 12, 2010 | 08:13 PM
latenighthaulers's Avatar
i did everything hotcummins is talking about and have put over 30,000 hard miles towing 15-18k at a time and my tc just now started to give up
Old Jan 12, 2010 | 10:09 PM
12v1911's Avatar
ok ill give that a try, my sig does have a fresh rebuild and shift kit installed, i just dont know how far to push it??. i use the truck for daily driver and virtually never tow so hopefully this is a safe mod
ok thanks ill give it a try, i forgot to mention that my sig does have a fresh rebuilt auto tranny with a shift kit. i just dont know how far to push it, i use my truck as a daily driver and virtually never tow. so hopefully it will be a safe mod. also would i benefit from a boost elbow at this point? thanks in advance
Old Jan 13, 2010 | 12:10 PM
yeah i think almost everyone on here has done this.....great mod to get a little more out of your truck! be sure to take the silincer ring out of the turbo sounds great
yeah the bost elbow will help or you can take a 1/4 inch hose clamp and put on the hose to help close the hose up some thats what i did to mine builds little more boost....be sure to get an aftermarket air filter to help compensate for the added fuel.....do all this and you will be good to go
Last edited by latenighthaulers; Jan 13, 2010 at 12:10 PM. Reason: Automerged Doublepost
Old Jan 16, 2010 | 05:42 PM
cumminspwrram59's Avatar
crank the fuel and well fab u up an intake and exhaust good luck buddy
Old Jan 18, 2010 | 01:23 PM
sparkplugsr4pussys's Avatar
could one of you please explain how to adjust the star wheel a little better, like is there any tricks, i have heard that you have to have a 2x4 to block of your tubo cause it will start free reving if you dont stall it out by pluging up the turbo to choke the engine out, thanks
Old Jan 18, 2010 | 02:27 PM
94 12valve's Avatar
thats only on 1st gens with a Bosch VE
Also use the search button there is tons of info on this here
6.5dieselman
Feb 26, 2015 04:45 PM
FELTONMICHAEL
Dec 28, 2014 01:09 PM
Mr. Walkway
Dec 11, 2014 10:28 AM
NiNjAassasin545
Dec 2, 2014 11:40 PM
94ifs
For Sale
Oct 23, 2014 01:35 PM
