???early 99 hard start???
Old Dec 28, 2009 | 09:58 AM
mandalorian's Avatar
Default ???early 99 hard start???
New to forum and glad to be a member. Have read a lot of issues on this but still not specific enough for the problem I'm encountering. Tried starting this morning, cranks fine then rolls over once. Get the WTS light and voltage is o.k. Spent about 10 min of this and it began to roll over a few more times. 5 mins later, it starts. Has had a new fuel heater 2 winters ago, new glow plugs, harness's, and relay last winter. I also just installed 2 new batteries yesterday. I had talked with my mech and he mentioned a possible compression issue. I did notice some white to blue smoke last year before the glow plugs but not since. Would compression be an issue??????
Old Dec 28, 2009 | 06:10 PM
BIGTIMMY's Avatar
MY EARLY 99 DOES THE SAME DAMN THING BUT ONLY ONCE IN AWHILE AND I NOTICE IT MORE ON DAYS WHEN IAM IN AND OUTTA THE TRUCK ALOT AND DONT USE MY WST AS MUCH
Old Dec 28, 2009 | 11:22 PM
Mine acts up in the morning. I work 3rds and do not have a place to plug in. Frustrating Ready to trade her off. Seems to be getting worse every year. Maybe its just old age!!
Old Dec 29, 2009 | 12:33 AM
CSIPSD's Avatar
How many miles? Have you checked the GPR? They can and do fail quite often... Install a wire on the motor side of the GPR and run it in the cab, put a LED there, then you know if the GPR is closing or not...
I would bet that is your issue, but it could be a leaking HPO issue, be it O rings, ICP sensor or IPR its hard to say with the info you have given...
Old Dec 29, 2009 | 09:24 AM
Truck has 237,000 on it. Pretty good idea of installing an in cab indicator from the relay. Never thought of that. Thanks
Old Dec 29, 2009 | 11:20 AM
CSIPSD's Avatar
Sounds like a glow plug issue to me...
Old Dec 29, 2009 | 10:52 PM
That would **** me off: Had new ones with harness installed last winter??
Old Dec 29, 2009 | 11:26 PM
CSIPSD's Avatar
Test it and go from there.
94turbostroker
Feb 26, 2016 07:51 PM
Dcbb93
Nov 30, 2015 10:18 AM
Blanton
Apr 15, 2015 06:29 PM
dfish001
Mar 30, 2015 03:07 PM
trab123
Feb 9, 2015 09:44 AM
