Airdog 150 install help
Old Dec 23, 2009 | 12:05 AM
cummins24's Avatar
Default Airdog 150 install help
I've got everything mounted like it should be i think. The problem is I'm not getting any diesel from the tank, so I can't prime it. maybe it's something simple and i don't realize it
Old Dec 23, 2009 | 01:40 AM
ChinookFE's Avatar
not insulting your intelligence, but do you have all the wires connected and plugs plugged in? I would trace each wire and just make sure that its connected to wherever its supposed to be at both ends of the harness.
Old Dec 23, 2009 | 02:13 PM
cummins24's Avatar
i can hear the pump run when i turn the key. but there are 3 connectiors i didn't use. i have the positive and negative hooked up and the one to the pump itself. am i missing one?
Old Dec 24, 2009 | 05:16 AM
ChinookFE's Avatar
there should be one that plugs into the ECM too I think...Im tryin to remember when I did mine
Old Dec 24, 2009 | 05:22 AM
12vcummins96's Avatar
when you installed the draw straw did you get it far enough in the tank also ive seen it take the side cover off the unit and make sure no trash got picked up
Old Dec 24, 2009 | 04:06 PM
2500superram's Avatar
did you fill the water separator with fuel,per the direction's
Old Dec 24, 2009 | 10:32 PM
cummins24's Avatar
i got it figured out. i heated the draw straw to fit more easily over the aluminum fitting and when it cooled it cracked . so i had to cut it and re-do it, luckily i'm not too far off the bottom of the tank but its all good to go now.
Old Dec 25, 2009 | 06:27 PM
enjoy the fuel pressure
Old Dec 25, 2009 | 07:10 PM
cummins24's Avatar
Old Dec 26, 2009 | 09:12 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
Jet A Fuel
Jun 5, 2015 03:28 PM
JesseJames288
Jun 4, 2015 06:35 AM
2ndcummins1
Mar 9, 2015 10:01 AM
justinsbeck
Nov 21, 2014 11:53 AM
