Water in fuel light on
Old Oct 12, 2009 | 02:59 AM
dancreswell82's Avatar
Default Water in fuel light on
Well I just bought a 97 F350 with a 99 7.3 in it a few weeks ago. I have not even seen the truck because I am deployed. I have had my dad going out and starting it and driving it a little bit every week. Well he just drove it last weekend with no problem. He went out to start it yesterday and on second attempt to start it blew white smoke, the water in fuel tank light came on and now won't run.
Has this happened to anyone, and what do I need to have my dad do to fix the problem? He said that the front tanki was half and the rear was about 1/4 full but it's only sat for 6 days. Is there an additive or something I can use to get rid of the water in the tank if that is what the problem is?
Thank you all for any help I can get!!!
Read more: https://www.dieselbombers.com/ford-p...#ixzz0Thphih5g
Old Oct 12, 2009 | 05:52 AM
wildbill's Avatar
Have someone pull the fuel filter, purge the fuel lines for a minute (turn on the key), suck out the filter bowl, then wipe the inside of it as clean as you can get. Replace the filter, restart the truck.
Old Oct 12, 2009 | 08:12 AM
Ok thanks, I will have him try that.
Old Oct 16, 2009 | 09:26 PM
robammerman's Avatar
There is a drain valve on the fuel filter bowl. Should be on the left side of the front of the bowl as you face towards it. It has a yellow lever on it. Open it and let it drain out. That lets out the water. Thanks for your service!
Old Oct 17, 2009 | 02:04 PM
Uncle Bubba's Avatar
Could also be somethin as simple as drying the sensor out. This time of the year with the sudden temperature shift condensation can build up in the sensor plug and trigger this also.
Old Oct 19, 2009 | 09:20 PM
wildbill's Avatar
Updates??
Old Oct 23, 2009 | 10:48 PM
wildbill's Avatar
Closing thread due to inactivity. Thread starter can reopen.
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
Mr.Gutsy
Feb 22, 2015 11:11 PM
moneypitk5
Feb 12, 2015 11:01 AM
yams
Dec 7, 2014 12:51 PM
