Trouble At Remrock
Old Sep 26, 2009 | 05:38 PM
Remrock's Avatar
Default Trouble At Remrock
2003 7.3 Parked after a 330 mile road trip,every thing was fine. Started it up the next day & only ran 4 cyls. Short warm up ex. temps. on left bank {drivers side} ran 85/95 deg. Right bank ran 125/130.The following fault codes were showen;
0279 Inj. circuit low
1298 IDM fail inj. high side open bank 1
1211 Inj. control pressure above or below
1316 IMD No diagnosis.
Old Sep 26, 2009 | 06:06 PM
Big Angry Hillbilly's Avatar
Couple different things can cause this.
Injector driver module, harness under the valve cover, valve cover gasket where the harness passes through it.
Pull the valve cover on the affected bank and see if the harness is plugged into the gasket.
DO NOT BACKPROBE WIRES THEY ARE EXTREMELY HIGH VOLTAGE AND WILL KILL YOU!!!!!!
Make sure the harness is plugged in good on both sides, and plugged into each injector. Do this with the key off.
I wish I could direct you a little more on teh P1316 - but my Ford access is so slow, if it was any slower it'd be going backwards. I will post up once I can get on there.
03 with a 7.3 - that's a rare machine.
Old Sep 26, 2009 | 06:13 PM
Ok so I got some limited info, the site is really REALLY slow today.
Most of the diagnostic steps are pointing towards the IDM.
Where are you located?
Old Sep 26, 2009 | 08:03 PM
Remrock's Avatar
Default Remrock
Thanks for quick help-tip MR Big Angry Hillbilly. The gasket connections were my first check & all is well. I have removed the IDM & I hope my Buddies at the Ford store can test it for me, the 400.00 to 600.00 $ price tag makes me want to make sure thats the problem.
THANK YOU, Remrock
Old Sep 27, 2009 | 02:42 AM
If you're anywhere close to Detroit I got a spare you can use to test.
Old Sep 27, 2009 | 02:44 AM
Oh an shake the IDM and see if it sounds like there's water in it. Real good place to put it Ford :rolleyes:
FWIW - One of my customers got one from Rock Auto and it was DIRT cheap.
You can also call Larry at Superior Turbo and Injection - FanClutch.com - heavy duty fan clutches and fan blades for all trucks and cars he will hook you up - Tell him I sent you.
Bighouse
Apr 9, 2015 06:51 PM
duramaxtuner
Chevy/GMC Duramax 01-04 LB7
Jan 26, 2015 11:11 AM
Gizmo52
Jan 6, 2015 11:58 AM
joshkhouse80
Nov 21, 2014 01:17 AM
7.3stroke
Oct 27, 2014 06:25 PM
