vp problem or something else?
Old Sep 26, 2009 | 04:27 PM
Duckdodgeman's Avatar
Default vp problem or something else?
Last week i was able to tow a 9000lb backhoe with my truck and this week i tried to tow it again and no go?it was very sluggish to accelerate and any kind of incline i had no power.My fuel pressure gauge only reached 8psi under a load and at idle i have 16psi w/ a fass ddrp.I took it to two diesel shops and they can explain it?I have no codes stored good fuel psi and volume. I was getting 15 psi of boost when i was having the problem.The truck starts and idles fine.They checked eveything except the vp pump they said i could only be tested on a bench is this true?I am still getting 22 mpg empty. The truck is a 00 ctd 4x4 w/4in turbo back,bhaf,fass ddrp,I did however install a boost elbow,boost fooler and a power puck after the problem accured and it seem to help a bit but not what i would expect.I had a new tranny put in 3 months ago with a upraded valve body,shift kit and a upgraded tc i think they said it was a triple disk tc so any help would be great. Could this be a vp44 problem?Also i do have egt,boost,fuel pressure and tranny gauges installed they wernt showing any weird readings.
Old Sep 26, 2009 | 04:37 PM
mysterync's Avatar
Do you have any of the PID data? The only way to diagnose the APPS is to determine if there is irregular voltage during the time of the problem! Sound most like a VP-44. To actully test the VP-44 it must go on the test bench!
Old Sep 26, 2009 | 05:52 PM
I am not sure what the pid data is?I did do the apps reset but it didnt help.Could this be an electrical issue or may the ecm is in need of a reflash?
Old Oct 10, 2009 | 08:29 PM
wildbill's Avatar
Updates??
Old Oct 14, 2009 | 07:04 PM
2500HeavyDuty's Avatar
closing thread due to lack of activity, the OP can re-open the thread if the problem is still there
burndiesel
10
Feb 7, 2023 01:15 AM
Jake9473
Jul 22, 2018 08:19 AM
jeremy01995
Sep 14, 2015 06:34 PM
thurobred1320
May 5, 2015 09:26 PM
Dadslb7
Dec 9, 2014 11:05 PM
