powerstroke in need of help
Old Sep 6, 2009 | 09:01 PM
99f350ringo's Avatar
Default powerstroke in need of help
i recently picked this truck up it was a work horse changed the bed and had some issues with the tail lights i.e. bad ground as it turns out had a ringing coming from the four way relay that isnt in the fuse box instead its beside it .... put it all back together witha good ground everyrthing works great except now it wont start i get no wait to start light and it just cranks over. also an interesting peice of info the key switch to start it also doesnt work someone hacked a push button into the dash they didnt cut anything they just spliced it all in its weird tho because it ran great yesterday with the ground issues any ideas at all id love to hear em helppppp!!!!
also i keep hearing about the cam sensor problems becuase it turns over but there is no movement of the tack sensor, pcm???hope not!!!
Old Sep 6, 2009 | 09:21 PM
dustys24valve's Avatar
This just happen on one of my trucks at work< check fuse #18 or #19 in the fuse panel, it should be marked pcm i think, I'm willng to bet it's blown ( 10 amp ).
Old Sep 7, 2009 | 02:01 PM
ya its not a fuse i tested em with a test light and pulled em and visually inspected thanks for triing tho
im not sure what i did but its running better tyhan ever i think the fuse was loose
Last edited by 99f350ringo; Sep 7, 2009 at 02:01 PM. Reason: Automerged Doublepost
Old Sep 7, 2009 | 07:37 PM
whatever work man
Old Sep 10, 2009 | 10:40 AM
stkdram55's Avatar
updates??
makuloco2000
Dec 20, 2015 11:19 PM
Lsugod85
Jun 20, 2015 05:14 PM
makuloco2000
Feb 15, 2015 02:31 PM
leaderbeanjr
For Sale
Jan 20, 2015 01:22 PM
southernbelle14
6.0L Performance
Dec 29, 2014 10:53 AM
