Leaking coolant 2001 Cummins
Old Aug 30, 2009 | 12:38 AM
mttjma2002's Avatar
Default Leaking coolant 2001 Cummins
I have a 2001 24v cummins and im leaking coolant. Checked it out tonight and its dripping down and off the oil pan on the front passanger corner of it. I have to fix my truck tommorow so i can work monday out of it. Do yall think water pump? The truck still runs cool.... so should i get a new o-ring, new water pump or both. Any help would be fantastic. Thank yall!
TC
Old Aug 30, 2009 | 12:40 AM
2500HeavyDuty's Avatar
how bad is it leaking?
Old Aug 30, 2009 | 09:18 AM
dieseldude03's Avatar
99% sure it's the water pump. Had to change mine a couple weeks ago. Be warned. The slow leak will only last a very short while. When these things finally let go, they'll spew every gallon of coolant right onto the ground!
Cummins used the same one from 1989 to present. You can get a brand new one for under $40.00 at Auto Parts Fast at RockAuto. About $60.00 at the local parts stores or $230.00 at the Dodge stealerhip.
Old Aug 30, 2009 | 09:50 AM
mttjma2002's Avatar
okay sweet! Yeah its dripping consistatly right now.... im headed to autozone right now. Thanks a millions guys.
Old Aug 30, 2009 | 10:29 AM
1st_gen_puller's Avatar
might just double check the and make sure its not the head gasket... hope not...
Old Aug 30, 2009 | 02:54 PM
Easiest way to check is to pop the hood and start the engine. There's a small "flat" cast into the engine block directly under the water pump. If you see the coolant start too pool on that flat, water pump is done.
Old Aug 30, 2009 | 10:54 PM
gradyc's Avatar
The water pump only has 2 bolts holding it the engine and on our 92 the bolts had loosened just enough for the sealing o-ring to start leaking but not enough to start a vibration. It might be worth checking that also.
Old Sep 10, 2009 | 10:52 AM
stkdram55's Avatar
updates??
JoeyMiR
9
Feb 3, 2018 10:05 PM
Shun70
Diesel Engine Conversions
Sep 21, 2015 01:39 AM
Shun70
Sep 20, 2015 10:52 PM
LittleBuck
23
May 21, 2015 06:06 PM
Stox5225
Nov 18, 2014 01:04 PM
