Ram/Cummins intermitant starting problem
Old Jul 4, 2009 | 11:51 AM
strider1a's Avatar
Default Ram/Cummins intermitant starting problem
On occasion when trying to start, I get very little or no engine cranking. After several attempts it will crank and start easily.
Batteries both show 12.5 volts.
Terminals are clean.
Is there a check I can do with a voltage tester to see if the cables are OK?
Doesn't seem like a solenoid or a stuck starter problem because I get a very brief crank [maybe a quarter of a second] when it happens.
Thanks,
Phil
Old Jul 4, 2009 | 11:55 AM
stkdram55's Avatar
what does the batteries get pulled down to when your trying to crank
Old Jul 4, 2009 | 12:02 PM
strider1a's Avatar
Don't know. I am working on this alone and cannot crank and test!
Old Jul 4, 2009 | 12:56 PM
wildbill's Avatar
Borrow a load tester and load test the battery. If it's good, got a starter problem (likely the brushes), if it tests bad, needs a new battery.
Old Jul 15, 2009 | 08:00 PM
wildbill's Avatar
Will send an email
Old Jul 23, 2009 | 05:09 PM
wildbill's Avatar
No response. Thread starter can reopen.
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
hurriedcoyte
Jun 19, 2015 06:26 AM
swartile
May 8, 2015 01:03 PM
Jmohr52
Nov 2, 2014 08:55 PM
