1997 powerstroke problem from superchip
Old Apr 11, 2009 | 05:58 PM
dura02rob's Avatar
Default 1997 powerstroke problem from superchip
I have a 1997 powerstroke f-250 with an auto tranny. today i hooked a friends superchip up to it. i followed all the procedures and did them correctly. now the truck will not drive. it starts and runs fine with a little roughness in the idle at first but smooths out shortly after. i need help badly. dont want to send it to the Ford House.
first thing the programmer said when we plugged it in was "Returning to STOCK". i found that quite odd since the truck has never been chipped or flashed or anything of that sort. the truck is completely stock, any help is greatly appreciated.
Old Apr 11, 2009 | 10:10 PM
Eryan's Avatar
Are you sure the truck has never been programmed? Sounds like the computer might need updating. I believe it can only be done through ford. Hook thge prgrammer back up and make sure the stock programming is installed. Have a good friend that knows a lot about fords and superchips. GRIDERS TRUCK SALES (270) 378-6258 Ask for SUE LANE or JD GRIDER
Old Apr 11, 2009 | 10:22 PM
2500HeavyDuty's Avatar
did your friend return his truck back to stock before letting you use it?
Old Apr 12, 2009 | 12:20 AM
NickH's Avatar
Glad to see you finally made it on to DB. Wish it was under different circumstances!
Too bad it wasn't from bombing that Duramax!
Old Apr 20, 2009 | 08:10 PM
wildbill's Avatar
Closing due to a one time post
burndiesel
10
Feb 7, 2023 01:15 AM
Jake9473
Jul 22, 2018 08:19 AM
Tylerbuckley
9
Sep 21, 2015 08:24 PM
jeremy01995
Sep 14, 2015 06:34 PM
signoremint
13
Oct 21, 2014 07:21 PM
