#100
Old Dec 25, 2008 | 04:36 PM
smokedout's Avatar
Default #100
How much more power will the #100 plate give me?
Old Dec 25, 2008 | 04:55 PM
Whit's Avatar
Site Mascot
Plenty.........its a big difference
Old Dec 25, 2008 | 04:59 PM
xzaq103's Avatar
FormerVendor
You should be able to break the tires loose.
Old Dec 25, 2008 | 06:35 PM
smokedout's Avatar
Default #100
How muck power will a #100 plate give me?
Old Dec 26, 2008 | 07:02 AM
97 D-Tec's Avatar
just make sure to watch that egt gauge your going to have a ton more fuel and air will be your next problem
Old Dec 26, 2008 | 09:54 AM
DieselDiva's Avatar
You will probably have 275 - 300 hp at the crank with a 100 plate.
Old Dec 26, 2008 | 08:36 PM
89silverbullet's Avatar
if im not mistaken its a #100 plate that takes away the aggresive fueling at low rpm's. but it fuels really hard at full throttle. i would say 100-120HP sounds good.
Old Dec 26, 2008 | 08:58 PM
greg@Lockitup's Avatar
Other way around.. 100 plate is not aggressive fueling at bottom end, 0 plate full fueling from get go...
Old Dec 26, 2008 | 09:05 PM
woops i meant to say #100 there. my bad
Old Dec 26, 2008 | 09:40 PM
Benjamin's Avatar
Bombardier
total i made 250hp 625tq @ 42psi on a stock 180hp pump, 100 plate, stock turbo, 4" exhaust, stock injectors, stock delivery valves, at the wheels on a DynoJet 224XLC
i had a fully built Goerend tranny and a tripple disc converter so factor in more than average drivetrain loss.... also i have 4 wheels in the rear not 2, another drivetrail loss of hp.....
