Trouble shooting a ford 7.3
Old Dec 9, 2008 | 12:17 PM
JVanOss's Avatar
Default Trouble shooting a ford 7.3
hay anybody gots any ideas on what can be wrong with a 7.3 diesel that will crank at the normal speed, spout a ton of black smoke and then start and stall right away? Im helping a friend fix her 1-ton. it aint the injectors, according to our local greasemonkeys. does it sound like maybe the glowplugs or what?
Old Dec 16, 2008 | 08:57 AM
wildbill's Avatar
So what did you find out? Was it the glow plugs?
Old Dec 20, 2008 | 04:46 PM
Mad Max's Avatar
Here is a link to troubleshooting a hard / no start problem with the 7.3. Good luck...
Hard/No Start? Check here first. - Diesel Forum - The Diesel Stop.com
Old Dec 20, 2008 | 08:46 PM
stud08's Avatar
sounds like it could be the fuel pressure regulator did u check to see if it has thrown any codes to the ecu
Old Dec 20, 2008 | 09:04 PM
wildbill's Avatar
Leak in the fuel line or filter. Maybe check that out.
Old Dec 20, 2008 | 09:38 PM
Benjamin's Avatar
Bombardier
first thing is you need to get your hands on a GOOD scanner like a MAC or Snapon or Matco that has a ton of test functions. the first thing to do is "BUZZ" test the injectors. they all should sound the same but if you have a bad one it'll sound a little "off". they start buzzing the number one injector whick is on the passenger side front then 2 is the driver side front and alternate sides with 7 being on the rear of the passenger side and 8 on the rear of the driver side. if that test fine then move on to looking at the HPOP pressures on the scan tool. it sounds to me like you are having a leaking injector (hence the black smoke) and a HPOP leak due to it shutting down after starting. this could be due to improper additives in the oil allowing for it to foam and allow air into the High Pressure oiling System that fires the injectors.
Old Dec 26, 2008 | 06:00 PM
wildbill's Avatar
Thread starter can reopen if he/she desires, as we can assume the problem has been fixed.
1997fordf350
Jan 15, 2015 06:12 PM
Nov 4, 2014 01:30 PM
7.3stroke
Oct 27, 2014 06:25 PM
Rx7man
Diesel Engine Conversions
Oct 15, 2014 04:00 AM
