Batteries Keep Dying
Old Jul 19, 2008 | 03:52 PM
wyoranch's Avatar
Default Batteries Keep Dying
2003 cummins SO. 47 RE
If my truck sits for 10 hours or more it wont start. Had the batteries checked, they are good. Alternator is good. Started a couple weeks ago. Cleaned all the cables. Cleaned them really good. During the same time my tranny started acting up. Turned out to be a bad governer and one more electronic thing in there. Tranny shop fixed it. Checked for codes and i got a P 2509 and a P 0700. Wiring is stock on truck, no accessories or aftermarket stuff wired directly to the batteries or anything.
Dont wanna fry any more electronic parts or hurt my batteries.
Thanks for the help
Old Jul 19, 2008 | 04:00 PM
Uncle Bubba's Avatar
In my case I changed out the batteries that checked out just fine and the battery cables and it fixed my problem like this. Come to find out that if your running the dual terminal batteries, that is posts both on the side and top that they are known to cause problems shorting out. As for the cables, if there is any broken wires in there they can short the batteries out and drain them.
Another guy on here found out his problem was the seat belt switch was shorting his out. If you do a search for seat belt it should turn that one up.
In the end you have short someplace there. Also try disconnecting the negative terminal on both batteries next time you shut it down and see if they still drain. If they do then the batteries are bad and the hot weather is killin them and if they don't it's a short someplace.
Old Jul 20, 2008 | 06:03 AM
wyoranch's Avatar
Well, the batteries tested good at NAPA, but they used this little cheap hand held tester. Went to AutoZone and they have a much more high end tester on a cart. One of them tested bad, so i replaced it. Started good this morning. Ill see how it does this afternoon. Hopefully thats all it was.
Old Jul 20, 2008 | 06:14 AM
If that left over battery is very old it will pull the new battery down to it's level. So unless it is a new battery itself they always recommend changing both batteries out at the same time. Them Auto Zone Gold's are some of the best rated batteries on the market.
Old Jul 20, 2008 | 07:22 AM
wyoranch's Avatar
didnt know that. i just bought it because thats where i was at. dont usually go to autozone, im a napa guy. the other one is not new, at least two years old
Old Jul 20, 2008 | 07:35 AM
By the way, I forgot to mention it before but glad to see ya back on the air and with a truck to boot. Life must be gettin better every day now.
Old Jul 20, 2008 | 09:21 AM
wyoranch's Avatar
Thanks. Yeah, i bought the '03 back in '05, but it was my wifes rig. We split up and i let her have it, was happy with my '93. But long story short, still in my name and not makin payments, i had to save it from bein repo'd. Then had to sell my '93
Old Jul 20, 2008 | 04:28 PM
Johnny Cetane's Avatar
I had an issue on my '96 where the intake heater relays were shorted internally and staying on ALL THE TIME. Battery drain was just one issue this caused. Might wanna check them out.
Old Jul 21, 2008 | 01:14 PM
wyoranch's Avatar
Well, looks as if the battery solved the problem. Still dont understand how two different testers at napa said the battery was good and the one at autozone showed it being bad. Either way, she sat for about 12 hours overnight and started like a champ this morning. Thanks for all the suggestions guys, hope i got it fixed
Old Jul 21, 2008 | 08:02 PM
Since it appears to be fixed now we'll close it out. Wyoranch, you can open it back up again anytime you want if there is more to add to it.
greasesheik
Apr 9, 2015 09:33 PM
somarillw
Feb 24, 2015 09:59 PM
willgoss
Ford Powerstroke 08-10 6.4L
Feb 12, 2015 09:52 PM
mpcampers
Dec 4, 2014 08:24 PM
Big _red _cummins
Nov 17, 2014 02:44 PM
