Should I replace my fuel pump?
Old Oct 9, 2020 | 01:37 PM
WILDKING's Avatar
Default Should I replace my fuel pump?
I noticed I was losing power about 1000 miles ago. I changed the fuel filter and checked it, has metal shavings in it after a 5000 mile change. If I change the fuel pump is there anything else I should check before I start it again? Truck idols and runs fine except for the power loss, it only has 150 thousand miles on it.
Old Sep 25, 2021 | 12:00 PM
chucks's Avatar
I would recommend that you check and replace the fuel strainer. It sits directly under the the fuel heater. I got my strainer kit from Fleetgard 3845400-S. If you do decide to replace the strainer, you will need a second square section o-ring to replace the seal on the fuel heater. I am trying to find a supplier for the o-ring.
Chucks
chevyduramax1
Feb 23, 2013 05:15 PM
Sawman
8
Nov 5, 2011 09:45 PM
david.schepers
Oct 18, 2011 09:00 AM
Sandman8105
15
Sep 18, 2010 04:52 PM
2003 Excursion 6.0
May 3, 2010 06:29 AM
