Two to Tango
Old Jul 10, 2020 | 12:09 AM
pastorjeep's Avatar
Default Two to Tango
Ok guys, I need some directions. Can anyone point me to a site or company that has the bell-housing drawings for the IDI pattern and the modern Ford V-8/V-10 pattern? I am planning to install a 1989 7.3 into a 08' Expedition and want to use the 4r75e. The torque converters use the same bolt pattern and hub/nose diameter. Should jut be able to transfer the mod pattern to the IDI adapter and drill and tap. I have found the basic numbers for each and they will Tango,just need the proper drawing with engine centerline to over lay. If all else fails I am going to bolt up the TC and clamp the trans to the block and center punch the holes.
Old Oct 18, 2020 | 11:41 AM
Stumblefoot's Avatar
Advance Adapters is where I would start....
Glsawyer.drig
Nov 23, 2017 05:41 PM
Rx7man
Diesel Engine Conversions
Oct 15, 2014 04:00 AM
Farmer_tom
Mar 8, 2012 08:02 PM
oldred73
6.9L & 7.3L Performance
Feb 27, 2012 02:57 PM
Spurrit
Jun 4, 2011 12:24 AM
