new to the diesel build
Old Nov 16, 2018 | 11:07 AM
DeaDeaDeaD's Avatar
Default new to the diesel build
hey. so I got a 2002 dodge ram 2500 24v back a few months ago and fixed it up a bit so it works great again. now I want to start building it up and am clueless with where to start.
the guy I bought it off said only work he ever did to it was install the Superchips MAX MircoTuner and replaced the fan with electric fan.
I cant figure out what to look for to see if anything else is done and where I should start with my own work cause I wanna get a decent amount of more power out of it. If anyone can help me I would be very grateful!!
Old Nov 17, 2018 | 10:45 AM
caleb_secrist's Avatar
What are your goals? I can give some solid insight once I know what you want from it?
Old Nov 17, 2018 | 06:14 PM
DeaDeaDeaD's Avatar
I want to get like 500hp outta it. Not in a rush to do everything right away but over the next few months start doing things
Old Nov 18, 2018 | 10:15 AM
First things first that tuner gotta go. Need something wiretap on these trucks. I have an edge juice right now with the hot unlock (which you need if you get one) but I will be switching to a quadzilla over the winter being I want more tunability.Second, think of turbo. a 62mm can make 450-500 with good sticks and a tune. May be pushing it may not depends on your exhaust wheel size. 64mm is a good turbo that will easily net 500+ little longer to spool however. can also find a 63mm wheel which is the middle of both.I Personally ran a 62/65/14 with 7x0.009 (150's) with water meth and a decently built trans with a dual disc TC, with headstuds of course.This setup can kill a good bit what youll run into on the streets and still tow with. This is a good starting platform. Or you can go ***** to the wall off the bat and I can help you there but be ready to spend 10k+.
Rian Henriksen
Feb 12, 2017 01:51 PM
CumminsCrazed
Jul 30, 2013 02:04 PM
mill3041
5.9L 12V Performance
Jul 22, 2013 07:02 PM
DieselWeasel
Mar 19, 2012 11:03 PM
cashwheel
Towing and Hauling
15
Nov 11, 2009 01:46 AM
