6.2 leak from tank.
Old Aug 18, 2018 | 07:58 PM
rebar's Avatar
Default 6.2 leak from tank.
I noticed after parked for 8 hours I left a 6" diesel stain at work. Its dripping from the fuel tank shield.
Has anyone else had a leak from this area and what's the most likely cause?
Thanks!
91 CK2500 4x4 6.2, SM465, 4:10 14 Bolt
Old Aug 26, 2018 | 12:06 AM
petew's Avatar
Dirt between the tank skid plate and tank has caused a hole in the tank. temp fix is drop the skid plate, find the leak, and fix it, or replace the tank. I have fixed pin holes with Seal All . Clean the area good with sandpaper, put a small amount of seal all on your finger, ,push it into the area that is leaking and hold it there for a few minutes, clean the surrounding area again and add a second coat. Often a single pin hole can be sealed with a sheet metal screw and seal all. Repairs have lasted 2 and 3 years for me on gas tanks and diesel tanks.
Old Aug 26, 2018 | 06:14 AM
rebar's Avatar
Thanks for that petew..
Can you tell me how to remove the shield without dropping the fuel tank? The two straps I see look like they are holding both together..
bowietrucking
Jan 8, 2012 12:47 PM
shvlhead78
Mar 23, 2011 05:32 PM
pullenplowen
9
Nov 7, 2009 06:37 PM
Cumminscowboy_101
10
Jun 23, 2008 08:56 AM
CumminsCrazed
5.9L 24V Performance
71
Jun 16, 2007 12:54 PM
