Trouble statrting
Old Mar 31, 2014 | 03:20 PM
electrician247's Avatar
Default Trouble statrting
Hello,
Im having some issues with my 97 chevy 6.5TD 202,000 miles.
Problem is it will crank for about 5 sec if not more before it starts. It does this every time i turn if off and go to start it up again. Things that were done. new starter,glow plugs, GP relay, lifter pump?? ( on frame rail), fuel filter. The previous owner did the relocate of the fuel mod? new batteries.
I can hear the lifter pump making noise as im waiting for the (wait to start) light to go off.
after it starts it runs good. Never dies or anything
Thanks a lot
Old Apr 1, 2014 | 11:21 PM
racer55's Avatar
Get the local parts house to check it for trouble codes.
Could be a crankshaft position sensor problem-AC Delco ONLY for CPS!
Another problem that is worse when engine is warm is a worn out injection pump.
Old Apr 2, 2014 | 10:03 AM
Thanks for the reply. it had 2 codes. abs sensor and speed sensor all were replaced and computer reset. If i turn it off for a few sec it starts up fine, just seems if it sits for more than 15 min it does it. maybe ill just replace the cps and see if that helps. I know injectors havent been changed in a while. Could that cause it?
Bighouse
Apr 9, 2015 06:51 PM
duramaxtuner
Chevy/GMC Duramax 01-04 LB7
Jan 26, 2015 11:11 AM
Gizmo52
Jan 6, 2015 11:58 AM
joshkhouse80
Nov 21, 2014 01:17 AM
7.3stroke
Oct 27, 2014 06:25 PM
