no boost
Old Mar 4, 2014 | 11:57 AM
wolfnexus77's Avatar
Default no boost
I have a 2000 F350 crew cab with the 7.3 it has felt as though I do not have any boost. Looking into it I replaced my line going from my EBPS to the exhaust manifold, no change. So I unplugged the EBPS just to see the difference and again no change so I changed the EBPS and again no change. Any ideas?
Old Mar 4, 2014 | 12:12 PM
joebob3093's Avatar
Moderator
Pressure test it to see if you have a leak
Old Mar 4, 2014 | 06:49 PM
What or how is the best way to test it for a leak?
Old Mar 4, 2014 | 08:30 PM
joebob3093's Avatar
Moderator
Do you have a boost gauge?
Old Mar 5, 2014 | 05:28 AM
I do not have one. Can you rent one?
Old Aug 1, 2014 | 06:59 PM
rod702352's Avatar
I'm having the same problem. Check your intercooler pipes, I had a hole in the driver side pipe. I fixed that abd it helped a little, but still don't have the power it used to. Any more ideas?
Old Aug 4, 2014 | 10:50 AM
Jayalon_7.3's Avatar
Make sure the wastegate / actuator on the turbo are functionally properly and not sticking
Old Aug 4, 2014 | 11:41 AM
Is there a way to make sure the waste gate/ actuator will not stick?
Old Aug 4, 2014 | 12:55 PM
There is a rod that connects the actuator to the wastegate. When you build boost, the rod should move and the wastegate should open Get a buddy under the hood and have him watch the rod. If it does not move, either the wastegate is sticking or you have issues with the actuator. In this case, work the wastegate loose by hand, clean and lube everything in that area, and test it again
Un4givn
10
Apr 27, 2015 01:58 AM
chaoticape
Jan 4, 2015 05:35 PM
ash23k
Dec 30, 2014 08:31 PM
Tsgbk9
Dec 23, 2014 11:54 AM
Crews8r
Dec 21, 2014 07:35 AM
