95 powerstroke help!
Old Dec 11, 2013 | 07:36 PM
95_powerstroker's Avatar
Default 95 powerstroke help!
hey y'all, im new to this site and fairly new to the world of diesels! I have a 95 f350 7.3 psd. I changed the fuel filter and cap and it didn't look bad in there at all. but now, the drain valve is leaking. it only leaks when the truck is not running. it is a steady *drip *drip *drip. I am just wondering if anyone would know where to start? Thanks!
Old Dec 12, 2013 | 01:25 PM
94turbostroker's Avatar
I'm not too for sure but I know there's a like a seal in there but to replace it I think you gotta get a new fuel bowl. You'll have to have the bowl out anyway to get to it easy.
Old Dec 12, 2013 | 02:23 PM
joebob3093's Avatar
Moderator
They make an oring kit that has all the rings for the drain valve
Old Dec 12, 2013 | 06:25 PM
Alright, its just inconvenient and is leaking more and more it seems. I did find a new drain valve online, maybe when I did the filter change I did it wrong? Are you supposed to drain the bowl when you replace it? I didn't drain it. I just popped the old one out and the put the new one in and the new gasket and cap.
Last edited by 95_powerstroker; Dec 12, 2013 at 06:25 PM. Reason: Automerged Doublepost
Old Dec 12, 2013 | 07:48 PM
joebob3093's Avatar
Moderator
I always drained mine when I had a fuel bowl
Old Dec 12, 2013 | 08:41 PM
I'm wondering if maybe you are supposed to drain it to relieve pressure in the fuel system when changing the filter? Maybe since I didn't drain it, there is too much pressure and its just leaking out of the drain valve?
Old Dec 12, 2013 | 09:41 PM
joebob3093's Avatar
Moderator
They just leak sometimes, I'm sure you didn't do it
makuloco2000
Dec 20, 2015 11:19 PM
Lsugod85
Jun 20, 2015 05:14 PM
makuloco2000
Feb 15, 2015 02:31 PM
leaderbeanjr
For Sale
Jan 20, 2015 01:22 PM
southernbelle14
6.0L Performance
Dec 29, 2014 10:53 AM
