hard cold start on 7.3 idi
Old Nov 16, 2013 | 12:42 PM
Timhill442's Avatar
Default hard cold start on 7.3 idi
i have changed out glow plugs and replaced the solenoid and it still wont start up cold
Old Nov 16, 2013 | 12:45 PM
Dortiz's Avatar
Have you replaced the return line caps, lines, and the o rings? That can cause an air intrusion, and fuel will leak back so you will have to bleed the lines
Old Nov 16, 2013 | 01:21 PM
Timhill442's Avatar
Thanks for the advise.I will give it a shot.
i didnt mention if i plug it in it starts right up.i have AC glow plugs in it and i have noticed a few postings that say use only MotorCraft
Last edited by Timhill442; Nov 16, 2013 at 01:21 PM. Reason: Automerged Doublepost
Old Nov 16, 2013 | 02:11 PM
Dortiz's Avatar
My truck had the same issue, and I use autolite plugs, after about 200 cold starts I pulled my plugs, and inspected along with test. No swelling in them what-so-ever. And tested out perfect, put them back in and had the same problem. Changed out my return lines, fittings and orings, then replaced my fuel filter with a single piece to get rid of the dual piece with the separator and viola no more cold start issue haha Took about half a crank in the morning to start up until my IP took a s**t on me about a month ago, now I'm fixing everything that I need on it while I pile up all the parts I want.
Old Nov 18, 2013 | 02:32 PM
7.3 excursion's Avatar
Default 7.3 cold start
Hey,
I would look at the injectors. If you are running 15/40 in cold climates, older injectors have a tough time until the oil heats up and thins out. Dump the oil and filter then use 5/40 synthetic Rotella. That should buy you some time. New injectors are big bucks
Old Nov 18, 2013 | 05:43 PM
Dortiz's Avatar
IDI injectors are about $35 a piece, just bought my whole set for less than $180
94turbostroker
Feb 26, 2016 07:51 PM
Dcbb93
Nov 30, 2015 10:18 AM
Bigredpowerstroke
Aug 14, 2015 10:31 AM
custom7.3
Nov 23, 2014 10:44 PM
g.logistics
9
Nov 22, 2014 08:54 AM
