Ford Powerstroke 08-10 6.4L Discussion of 6.4 Liter Ford Powerstroke Turbo Diesels
EGR and DPF missing programmer
Old Nov 10, 2013 | 12:16 PM
Gio Armani's Avatar
Question EGR and DPF missing programmer
I bought an 08 350 with both deletes and at some point I guess it had a programmer on it. They sold it to me without it but ran like it was new until it went into regen one time and just died on my way to work. Now the key turns and all gauges and accessories turn on fine but it wont crank over, it won't start now. It blows white smoke and bogs down a little until it finishes regen but as stated before ran fine. I recently purchased a Spartan but wondering will that fix it. Anyone have any ideas?? I'm open to suggestions.
Old Nov 11, 2013 | 09:22 PM
jake74's Avatar
Sounds like someone pulled there tuner off before selling it to you and that's shitty of them. If the spartan tuner is a dpf delete tuner it should fix you right up.
Old Nov 12, 2013 | 12:10 PM
96Power's Avatar
Sounds to me like someone didn't want to give up a $1200 tuner. Only 2 ways to fix the problem.
#1 make sure your Spartan has a DPF Delete program if not you can get one for $1200 and it should work.
#2 Take is to a muffler shop that can get thier hands on a DPF system and have it put back on.
Also check your oil. If it's been Regenerating without the delete and filter then you have a higher chance of fuel getting past the piston and down into the oil near the cam. This will cause some blueish white smoke to come out of your exhaust pipe. If its too full or smells like fuel change it immediatly.
Old Nov 15, 2013 | 06:30 PM
Gio Armani's Avatar
thank you both, I have since purchased a Spartan with the EGR and DPF delete on them but the times it has gone into regen it has produced white smoke. I recently got an oil change and only drove It once before it went into limp mode.
Old Nov 16, 2013 | 03:22 PM
gunman41mag's Avatar
Moderator
If you put the SPARTAN tune in your truck, it shouldn't be doing any regen
RAW
6.7 Liter Dodge Cummins 2013+
9
Apr 17, 2017 02:36 PM
TOM81650
Price Quote - Request A Price
Sep 17, 2015 02:07 AM
kestmic1
Jun 8, 2015 12:44 PM
willyam
May 19, 2015 10:20 AM
