98 6.5 td 90' oil filter adapter o ring sizes
Old Sep 25, 2013 | 08:15 PM
b.vonbargen's Avatar
Default 98 6.5 td 90' oil filter adapter o ring sizes
Just finished new replacing the leaking oil lines with hydraulic hoses . I had to take the oil adapter off to remove the old line adapters and replace them with street ells. Cleaned up the housing and replaced the filter housing and now I have a new leak at the block to filter housing . Does anyone know the o ring sizes so I can order new ones while I continue oil spraying the underside of the truck.
Old Sep 26, 2013 | 03:12 PM
racer55's Avatar
Easiest to get them from leroydiesel.com.
Old Sep 26, 2013 | 09:40 PM
Just finished up the oil filter 90' rebuild . I removed the old o rings and matched them up with new ones. I used a 115 on the mount bolt and a 215 in the housing to seal agaist the mount bolt . The block to adapter housing I used a 235 . Went together smoothly. No leaks . Total cost for lines fittings and orings . 72.00 $ . Hopefully last the life of the truck .
Old Sep 26, 2020 | 04:25 PM
petew's Avatar
I just went thro hell trying to find O rings for my 98 ,6.5. The Dorman kit, Nappa, don't fit a 6.5. GM wanted $39.00 for 3 o rings and had to order them in.
A seal shop suplied the above rings for $3.39 , . No leaks now.
They recomended Nitril 70 , Duro O ring material.
Thanks for the size information. It made it super easy at the seal shop counter.
Pete
russellflemister
Aug 19, 2013 01:34 PM
chevy driver
Apr 8, 2013 09:21 PM
smokindodge1
Feb 10, 2013 10:22 PM
Dorian
Aug 24, 2012 05:46 AM
russellflemister
Jul 19, 2012 06:17 PM
