ATS Transmission Hard Shift
Old Aug 20, 2013 | 01:43 PM
01FordHMS's Avatar
Default ATS Transmission Hard Shift
I just put in a stage 2 ATS transmission that shifts very hard from 2nd to 3rd gear. When talking to ATS they tell me this is normal however if wanted they can make it shift softer by changing out some parts. Does anyone out there have this problem? I hate to spend the money to R&R it if this is normal performance. This is a head jerking shift.
Old Aug 29, 2013 | 11:04 AM
Smokey Freedom's Avatar
Whats your chip? I ran into this once. DP tuner not tuned for a built trans. It would shift fine under hard acceleration but just easy driving 1-2 would bark the tires and snap your neck. Had tunes rewrote to keep line pressure in spec and worked like a dream.
Old Aug 31, 2013 | 08:35 PM
tiremann9669's Avatar
Never heard anything good about ATS
Old Sep 12, 2013 | 05:01 PM
Dirtydiesel69's Avatar
I have a 99 7.3 that shifts really 2nd and 3rd gear i dont under stand y it this happening if anyone know y please i have a ts 6 postion chip that helps i run it hard it gets hard the higher rpm
Thanks dirtydiesel
Old Nov 7, 2013 | 09:23 AM
Jason7three's Avatar
Mine just drops it in from 2nd to 3rd. Gets worse as the rpms go up. I just turn overdrive off when im getting up to speed then turn it on.
Old Nov 13, 2013 | 09:53 AM
importrepairguy's Avatar
If your truck is chipped, needs to be re-tuned or calibrated for the beefed up trans. If its not tuned, then your at the mercy of ATS.
Good luck
Gman30
Jun 11, 2015 09:57 PM
EverettsGMC
Mar 29, 2015 05:42 PM
SixSpeed
Jan 11, 2015 01:41 AM
out6grand
5.9L CR Performance
48
Dec 19, 2014 10:05 PM
motormayhem
Nov 16, 2014 02:13 PM
